Bandsaw (Rockwell 14)
This is a Rockwell 14" wheel, 93 1/4" blade bandsaw. It is capable of high speed wood cutting and low speed metal cutting, but we use it exclusively on the high speed setting.
It has a 2 speed clutch at the back that should ideally let you switch between high speed wood cutting and slow speed metal cutting.
Consumables:
We typically order replacement blades from R&D Bandsaws (http://tufftooth.ca)
- The speed clutch is tight, requiring a lot of force to properly set.
 - needs oil
This item came from Peter Clark (Simon's Dad). It was used in the brake-lining industry since new, cutting brake pads in half for testing purposes. It now belongs to Diyode.
Rockwell 14" Metal cutting bandsaw
 Model : 28-300
 S/N : 313580
