Laser Printer (Colour)
			The Brother HL-3045CN colour laser printer is for official DIYode use only. It should not be generally used as the colour toner is extremely expensive.
If you need to use it please contact Simon first.
Takes Brother TN-210 BK/C/M/Y toner cartridges.
Procedure to reset Toner levels
1) Turn the printer off and then on again.
2) Open cover.
3) Press Cancel and Secure Print buttons at the same time.
4) Press the + button and scroll through the colors that need to be reset. (reset both STR and STD when prompted. I just reset them all.
5) Press OK (twice, once for STR and STD)
6) You're done. You don't even need to take the cartridges out and the printer thinks you just installed four new toner cartridges.
How to refill the toner cartridge
http://www.youtube.com/watch?v=lQQ2cLDMQgc
					Nice work, with lots of good ideas. I have been making rosettes on the lathe for years since the <a href="http://drillpressselect.com/">drill press</a> likes to chatter and chew just before I hit the proper depth.
							- drill press
							 Jul 28 2015
